Wraith Electronics box
To The Crawl Space, will the front and rear boxes work on a Axial SCX10 frame running Axial Wraith differentials? I was just wondering. Your work is fantastic. Thank you
honestly we've never tried to fit the wraith boxes on an SCX10, but it would hurt to try "thumbsup" We have plans for a SCX10 specific box just need to find the time to suss it all out.
This chassis is chopped down in front so don't let that mess with anyone :mrgreen:
The rear tray works great between the front shock hoops, you can drill holes through the top of the tray to "snap" over the top of the ashock hoops and hold them in place with the body pins that are used to adjust the height of the body posts :mrgreen:
Front view
The front Wraith box will fit similar in fashion but only to the first part of the front of the box. You can squeeze the box to the second larger part of the box but the shock hoops flex out which I don't advise
Here the front WRaith box on the front of the SCX10 shock hoops.
Now with this shortened chasis and wheelbase its hard to judge if the boxes will have clearance of axle mounted servo but the boxes will clear a standard wheelebase, ie; 12.3" plus if people start getting into the chassis mount servos that a pushed up to the front and perpendicular to the chassis rails the boxes will work "thumbsup":mrgreen:"thumbsup":mrgreen:"thumbsup":mrgreen:
Actually i have the electronic box up front and the sensor wire that came with the motor is kind of short.
Ah ok, depending on how you have your running gear set up you can run the motor wires and sensor wire through the bottom of the front box. If you're concerned with waterproofing you can use some plastidip to seal the hole "thumbsup"
I have thought about that. It might work but it might be a really tight stretch. I just dont want to put a hole on this nice looking electronic box, ya know.
I left a hole in the bottom of my box for servo wiring.
I did not seal the hole as it is the low point and want any moisture that may get in there to drain out.
Any ETA? Was going to place an order for some other parts today, but wanted to find out when these would be available first. Thanks!
I just ordered the 100% front tray, rear tray, and rear tray cover. The items have already been packaged and waiting for parcel to pick the box up. Point being, the Crawl Space has outstanding customer service and turn around time.
Every e-mail was replied to in under 12 hours and even a phone call was returned within less than 1 hour.
I will continue to support The Crawl Space and its awesome owners. Thank you Ikaika.
Vengeance aka Jason
