kenworth winch truck all wheel drive
SEMIJOE
trenton
hey guys
ive been working on this truck for a couple of weeks now, I figure its time to post
I started with the basic king kit, parted about 50% out
any way , this a little how-too on the all wheel drive chassis.
time for the mock -up rails, the black rails are the stock king/globe liner rails. as you can see the stock holes, the blue rails are the prototype , to make the chassis an all wheel drive
we have to move some of the holes
the rear suspension holes have to be moved all the way down as pictures
the front holes have to be moved to the center of the rails as pictured
now on the read suspension , sense you move it downward, the center crossmember has to be flip and the nipples need to be cut off
heres what the rear should look like
for the front axle I went with a tlt-1 Tamiya , im also adding a 3rd rear axle , axles will be painted orange . this truck will be crazy colors
to make this work using a tlt-1 axle , you need to do a little modding, you have to mount the axle flesh against the leafs using no blocks, the leafs have a bipple on them, so you habe drill a little sink hole . also the tlt- axle holes are not drill all the way through, so you have to drll it out
axle is mounted, here the new rails I cut and drilled , and also adde all alum crossmembers
the 3rd axle, tag axle , you use the same parts of the rear suspension accept for the leafs springs, here you need mount the plate 4 1/8 inch forward, you also need to drill a hole as pictured
next you mount the stock control arms as pictured
sense theres is no leaf, your probably wondering what is keeping it pushed downward, its the shock, the shock it self is plenty of force
here the steering servo is mount and hooked up
front view
using for a front rim you have to use the rear inner rim, ive added some nut and bolts to give a little more detail, but myself wont be using this wheels
starting to come to life here, here you can see I using the semi bigrib 3-speed not the f350, I have a rod that replaces the top rod making it a through and through
another view , for pulling power im using an 80 turn motor from rc4wd
rear view
for the front wheels im using the rear inner bud wheel fom rc4wd, ive put a super single tire on it, and added a couple of spacers to make it wider
while im waiting on cab to come in I will get started on the dual winch platform
time to show I covert this king cab into a k/w , pictured is a stock cab
removed sleeper and fender, this is easy to do, I use a utility knife , scare it / pop it
next the grill backer and hood sides
all apart
next I titled the nose 17mm , replaced new hood sides , mounted the grill backer and cut the back out of the cab , the back of the cab has to extended and the roof has to be raised
the back of the cab I use part of the sleeper, it works perfect , ive also lifted the back of the roof 6mm
next I cut the rear windows out and dipped the side door windows
the k/w has double head light buckets, so I used the stock rear bumper for the buckets
heres the cab prefitted
today I started on the winch , im using the Tamiya worm gear set up, it has the option for different gear ratios, I went with 1400:1 ratio, this kit was 12.00usd
ive also installed 2x back up lights and 4 running lights
ive added the mesh , air lines and trailer hook up
here I made a tool box
I paint the cage yellow
platform is orange
Wow, the more I see of your work the more I want to build one.
I want some fuel tanks...do you know where I can find some without buying a kit ? I remember seeing a web site some time back, but can't seem to find it now.
TIA Joe
I modded the stock aircleans , I cut the tube off , added mesh to the top nd plugged the hole and covering it with chrome paper
I started working on the bed, the plateform , has it where you cab drag a trailer right on to the bed , this has 2 cross beams , adjust width pins, and alum incerts for the weight
great build as usual. What do you use to cut your styrene materials with? Your part edges and fitment always look flawless.
