JeremyH
Gotcha. I still have a problem with the rear axle coming through the gate in the wrong direction for the first time...
Just because something isnt written in the rules doesnt mean that its OK to do.
It doesnt say we cant leave the gate after half progressed, turn around, enter it from the wrong direction to get the other half of progress because MOST people KNOW thats not how the rules were intended. MOST people understand that when we lay down gates with the arrows pointed in a certain direction that THATS the direction you must take to earn progress.
If you remember...both Jeremy & I agreed that it was legal. Why? Because he made a clean progress in the INTENDED direction. What you do in the video isnt the same. I dont understand how you're comparing the two. IMO we DID have common sense & thats why it was ruled as legal.
How can you jump OVER a pair of gates legally but not crawl UNDER a pair legally?
You ARE a smart cat Erik. We all realize that but sometimes that big ol brain of yours gets going & you look for the holes in the rules...which is fine but claiming that because there's no specific rule outlining what is or isnt a legal attempt, what is or isnt defined as the end of said attempt etc is reaching IMO. I say common sense because MOST people understand & will agree without a written rule that if you enter a gate then back out...thats your 1st attempt. Once you enter the gates again from ANY direction...thats attempt 2.
Nabils example would be MUCH more questionable in my mind since he never left the gates...which makes it...say it with me class...THE SAME ATTEMPT, NOT 2. "thumbsup"
JD
yessir I believe this is what Nabil was describing...
seems so damn straight forward to me.
Ok, so is this legal or illegal?
Because?
Progress is awarded when during the same attempt
and in the intended course direction at least one front and one rear tire passes completely through the gate.
To receive the progress bonus without a gate penalty, all four tires must pass completely through the gate during the same attempt and in the intended course direction
keep in mind erik, this is not what you did in the video.
The rear enters is the wrong direction before the back flip.
The rear enters in the wrong direction before the back flip. Both the front AND rear must enter from the correct direction in the same attempt.
I will let you and Krawl argue it out then. :lmao:
at the moment i would say legal.... And here is why.
1st attempt:
He entered the gate in the right direction, he then manuvered over the gate , not coming in contact with the gate itself, while still in the gate and exited the gate.
This is assuming that he completley exited the gate ( past the front plane with the reaar tires)
2nd attempt:
After he exited the gate, he climbs the wall, before re-entering the gate while backfliping through it in the right direction.
Gate cleared, no points given, as long as gate was not touched at any time and assuming all four tires went through the gates and not over them.
Keep in mind erik, this is not what you did in the video.
Youre 100% right. If you read back, this is why I wanted definitions before the video.
At the time, I had no idea what definitions we would put on something like this.
You guys are saying you need to enter a gate on every attempt, fine.
You guys are saying you cannot leave the gate or you need to re enter, fine.
Those rules or ideas are not written anywhere nor defined. I feel like I know the rules pretty well and its all up to personal interpretation and opinion to figure those two aspects out. Like I just said, I am fine with those interpretations, lets roll.
Had I known these interpretations and additions the the rules, I could have easily driven it that way and made the video that way.
i think this situation is the quirk.
you can enter a gate in the right direction and do whatever you want as far as manuevering inside said gate. he could flip twist ar whatever while inside the gate to cause him to end up in the wrong direction in the gate,
but his exit of the gate is no different than pulling into a gate then reversing out of a gate ( in this situation)
the key is if he completly exits the gate reguardless of direction he is now on his second attempt at the gate that is cleared clean as he re-enters the gate flipping through it.
Yes...this is what he's been trying to get at. Nabil's idea really provided some clearer wording on what was being described earlier.
