Charlie-III
So after an email to EddieO about the brushes on my Apocalypse 27T type r motor I bought a few years ago he convinced me that I need to cut the comm since I ran through a good 60% of my brushes. I posted here a few years ago about a new Integy super lathe 3 that I bought and was all set to cut my comm when it was needed but a few years went by and I never really used the rig much so the lathe never got used. Of course the idiot in me decided I wouldn't need the lathe so I sold it 3 months ago to a buddy go figure. So here we are at the present and guess what I need a damn lathe again LOL. I hate asking to borrow things so I set off to Ebay and ended up winning a Trinity RC4114 lathe for 21 bucks, is this a good lathe, has me concerned reading binaryterrors post. It is the model that comes with v blocks as well as bearing guides and has maybe made 1 or 2 passes in its life. The seller was awesome and he decided to give me whatever extra arms he had to practice making the cuts before attacking my good brood and Holmes motors. I am a little nervous to try my hand at this and to be honest I never used the Integy because i never had a arm to practice on. I went onto amazon and found some cheap ar4 carbide bits for 1.79 each so I grabbed 5 to practice with, hope they are not crap. I also decided if I am going to be rebuilding i would grab some motor tools, grabbed a hood alignment tool, brush spring nut tool, brush cutter/serrator, extra 10oz laydown springs, extra 766 brushes and a diamond bit for the cuts on my good arms. All this stuff ran me a total of 110 shipped to my door, now I wait impatiently LOL.
So with that here are my few questions that I am not totally sure of. EddieO said to run a stock motor on a 3 cell pack, I have a nip axial 27T motor to use and a computer power supply converted with 3.5v, 5v and 12v for power. I also have a special variable circuit to cut voltage down but it is only rated to 3amps so idk if thats usable but it gives me the option to really dial voltage in if need be. I was thinking that the axial 27T on 3.5v would be good but then was told by other sources that 55T on 12v is the best so what is it. I am also not sure where the best place to start the cut is, do I start at the comm tabs side and work to the end and stop, reset back to the tabs and pass again or do you start at the tabs, work to the end and pass back to the tabs as 1 pass? Also is there an easy way to tell if my bit is square since the lathe is used?
hah revived again 1 year later LOL.
Long but good post on your end.
Bits, since we're cutting copper, the bits last "forever" unless you drop them basically.
Most lathes can do a decent job cutting, making sure the lathe is square (the comm ends up the same diameter from one end to another) is among the biggest things to check.
Cutting speed, there is an RPM on the comm to be cut you want, the voltage required to get that RPM is based on the motor turns driving the lathe. I believe a 27T wants ~3 volts, a higher wind motor wants more voltage to get a higher RPM.
Both should end up at about the same speed at the armature you're cutting. Hope that makes sense.
Cutting, I line the bit up with the comm near the "free end" (away from the windings) and slowly bring the bit in until it contacts the arm in a spot where the brushes DON'T ride.
Move the cutter off the end of the arm, dial it in a couple notches on the feed wheel and start the 1st cut. This goes from the free end towards the windings. It takes ~15 seconds to make one pass, then move the bit back to your starting point taking another ~15 seconds.
Move the bit in a couple of notches on the feed wheel and repeat.
Keep going until you have a clean comm.
