on that side note- out of all the brushed motors i tried in the old girl, the original 750 tamiya can had the best power, albeit the slowest, and i do mean slow... the traxxas motors i tried were new, and didnt have the grunt to get it over my log pile test area on my property. it would dig in and bind with the 775 titan, the 20t 550 can wouldnt even get that far. in comes rc4wd 540 adapter plate and tacon 1100kv b/l... she is in a whole new ballgame and got the power to clear damn near anything i aimed it at. i dont run it much because the motor is strong enough to turn the 25 year old transmission into shrapnel..
Pic of your log pile?????
Its going to be difficult to make somewhat fair comparisons.
Surfaces are different in many areas.
The best chance of a fair test comparison will be from someone who has an assortment of power set ups and gears and do the test unbiased.
Too many variable come into play with testing from all over such as different enviroments (temps/surfaces/Altitiudes etc...).
No doubt a brushless is capable of more power and enough torque to rip rigs to shreds but its not about who can make the most power..Its about controllability and finesse and in most cases of trail running or rock crawling that's what most will want...Yes; there are trails or courses or scenarios where you can use a lot more speed and in a timed event the brushless can fit the bill.
A fair comparison of something is when all is exactly the same but the one item or items in question.
If you put a 13.5 which is claimed an equivalent of a 27T brushed motor with all else being the same.(ie battery power/gearing/tires/vehicle weight etc...the brushless will not win out against that brushed motor for the majority of trail/crawling use...You have to go with steeper gearing for a reason with a brushless to get the torque the brushed has at lower rpm.
They both have advantages but brushless is not the holy grail of power.
Why would HH and Brood invest so much engineering and development into brushed motors if brushless was such a superior source of power?
Brushless is getting better with age and development but still loses out to a brushed motor for bottom end grunt.
If you like brushless then simply use that to power your rig and be happy in your mind thinking is a better power source..I do with my brushed set up..so its ok we all like what we like..but a fair comparison is going to be a difficult task with so many variables that come into play,,, but good luck with the comparison..Ill be there with my 2 cents on the results.
Stock AE2 ESC,Custom27T brushed mod motor,2s lipo (25c) power with 16t pinion/87t spur running 1.9 ripsaws in a 6lb SCX10 is my set up and I would put it against a 13.5 brushless set up anyday on the trail with all else being equal.
If you want a drag race comparison ill give it my best shot with bumping my timing up and re gearing but I wouldn't be surprised if I lost and happily give congrats on the win.
