Rowdys there's no "I" in team Bully 2
Something that attaches to the top and uses cf spacers to adjust elevation so it is easier to adjust. Also a pass through hole for the rod ends so it is easier to mount.
I like the treaded hole for the upper link mounting screw. We designed it like that so the uppers would be perfectly aligned. Yes, there is an extra step when assembling or dismantling, but I think the trade off is fair.
I like to be able to add spacers to make the uppers more parallel to each other. The 3mm bolts I have found long enough to do this have a shoulder on them.
There are 3mm screws long enough, I used to space the ones on my xr out that way.
Threads are not nearly as strong as a shoulder. This is a very high stress area for us guys that like to ram the rods ends into rocks. Too late holes drilled.
I have used these in the past, and McMaster has them up to 50mm with or without shoulders.
The strength of the bolt itself. I am not the best at explaining myself sometimes.
I guess if your spacing way out a big shoulder bolt wouldn't bend as easily as a full threaded one, I'm guessing that's what your talking about.
Got bored and put an offset bend in the drag link, not quite enough but works for now. Once I get a chance to try this setup on the rocks and if it works I will get the correct length link, this one is a little short but made to work with Jato rod ends, ideally I will get a longer link and use Revos.
