fyrstormer
I finished my Wraith build. I did a whole bunch of stuff to this vehicle in a short amount of time:
- Replaced the motor
- Rebuilt the transmission with hardened-steel gears
- Replaced the 48-pitch pinion and spur gears with 32-pitch gears
- Replaced the stock driveshafts with MIP hardened-steel driveshafts
- Replaced the diff gears with Hot Racing hardened-steel gears (including an overdrive gear for the front axle, to improve "grab" when climbing and reduce "push" in corners)
- Replaced the front dogbones with RC4WD CVDs
- Replaced the stock plastic hubs with TopCAD aluminum hubs
- Replaced the stock plastic front bumper supports with RC4WD aluminum supports
- Replaced the stock wheels and tires with R35 Ripsaws mounted on Axial Walker Evans beadlocks (including Vanquish aluminum SLW spacers)
- Added 2oz. Axial clamp-on weights in the front wheels, to lower the center of gravity a bit
- Rebuilt the shocks with aluminum bodies, mounts, and spring collars
- Replaced the stock plastic suspension and steering linkages with titanium linkages from Blue Monkey RC
- Added bash guards from Blue Monkey RC
- Replaced the stock servo with a Hitec HS-7955TG titanium-gear servo (including an Axial clamping 24-spline servo horn)
This is a high-torque vehicle and I don't like breaking parts, so from the motor spindle to the wheel hubs, the only parts of the drivetrain that *aren't* made of hardened steel are the spur gear and the diff bodies -- everything else is rock-solid.
The suspension and steering linkages are titanium, because I know perfectly well they're going to get bashed into stuff and dragged over rocks, and neither plastic nor aluminum will hold up as well as I want. The lower suspension links are a high-clearance design, which helps a bit, but there are obvious scrape-marks on them already, so I'm confident I made the right choice in getting the more expensive titanium links.
Various people told me I didn't need bash guards for the diffs, but after seeing how quickly the diff covers were getting chewed up, I decided to get bash guards anyway. Blue Monkey RC makes a nice set that have a low profile and are made of steel instead of aluminum, so they can actually do the job that bash guards are supposed to do.
This is what they looked like new:
...and this is what they look like after a week of unapologetic bashing:
The rear bash guard doesn't look as bad, but it's got its fair share of scrapes on the underside. The important thing is, the replacement diff covers I got still look pristine, instead of having the fins bent and broken off, like the original pair had.
I don't like plastic shocks, but I didn't like the look of the Axial aluminum shocks, so I bought green and black aluminum parts from STRC, and rebuilt the stock shocks. They work a little smoother, just like metal shocks always do.
I opted to keep the speed of the stock motor, but I wanted more durability, and I didn't want to drop a bunch of money on a sensored brushless system, so I opted to install a name-brand rebuildable brushed motor. While it was originally intended for something more like a touring car or a go-fast monster truck, this Team Orion 20-turn motor is holding up great in my Wraith. It doesn't get too hot, the battery lasts forever, and it produces noticeably more torque than the original throwaway motor did. I added silver brushes to improve conductivity, and the next thing I noticed was I had to tighten the slipper clutch to keep the motor from spinning freely when I pegged the throttle, so that improved torque output as well.
In the three weeks I've had it, this vehicle has completely supplanted my go-fast vehicles as the vehicle I'm most likely to play with on any given day. It comes with lights, so I can run it in the dark after I get home from work, and the fact that it climbs over stuff instead of going fast means that I can actually have fun with it in the dark without worrying about destroying it against the side of a curb. This vehicle is one of my best RC purchases to-date.
