goldwing
I won this truck at the ECSC in August on a ticket draw, I started the build and did not like the way the suspension worked! without the spring loaded shocks the shackles just folded up and the leaf springs did nothing!
On the front I moved the shackles to the rear.
You just can't drill the old frame hole, you will break though the bottom I milled and then drilled a #20 drill
On the rear I moved the shackle block back .310ths and drilled new hole for shackle bolt
This is my new Tcase mount over 1/2'' more ground clearance.
The leafs will help do the job!
