Eric113 Ibex goat
eric113
Moderator Rule Breaker
Moderator
Austin, Tx
Current Setup
Front Axle
Axial wraith axle
Vanquish wraith chub
Vanquish wraith knuckles
Vanquish diff cover
Vanquish bearing caps
Vanquish Ti steering links
Locked RC F.I. locker
Dinky Rc S mount
Axial Wraith universal
Gunnar custom pins
Avid bearings
Axial stock gears
Rear Axle
Axial wraith axle
Vanquish diff cover
Dinky S mount
Locked Up F.I. locker
Axial Stock gears
Gunnar custom pins
Rolling Stock
Vanquish SSZ-9's
Axial R35 ripsaws vented
stock foams
Transmission
Axial steel ouputs
Axial stock motor plate
Gunnar pin for idler gear
Driveshafts
Axial W8B HD driveshafts
Suspension
Vanquish Ti wraith lower links
??? Upper links
Traxxas big shocks 4"
Rod end cap mod
??? Mini losi springs
RPM 2 stage shock pistons
??? Weight oil
Chassis and Body
Axial wraith skid plate
Mitchell machine & fab chassis
Mitchell custom panels
Axial wraith interior
Stainless steel hardware
Power and Control
??? waterproof ESC
Castle Creations BEC Pro
Tekin pro 4 3300kv waterproof
??? steering servos x2
Futaba 4PK
Futaba R604FS RX
Quicksand winch
Heyok 4amp relay winch controller
??? 4s & 6s lipos
I bought a chassis made by Mitchell machine & fab, that RCC member reworked the chassis. Updates will be slow as I will be moving end of month.
The start.
I'm diggin it "thumbsup". Needs a solid hood or something different. Jmo:mrgreen:
You lost me. What you mean Willis?
Speak of which I do need panels. The width of wraith hood is good, but the grill is too short length.
Build is going to be on hold for another week or 2.Moving :roll:
Have one drawn up and 3d printed to match the hood line of a wraith. Then just cut off the lexan grill area.
That works. Or have few vac formed.
When you building your goat is that what you going to do for the hood and grill?
Super lame update. But whatev's. These are parts I been need to install.
Axle parts.
More axle parts and chassis parts.
Dlux G10 ultra 4 steering truss's. Anyone legit knows if CA edges helps or not?
Dlux big bearing 5x13 housings.
Keeping the with VP theme. I have VP upper links on the way to match the lowers.
Looking good.
What's sup on the exposed lower rod ends with those mounts? Non-issue for rod end abuse?
Nice to see the DCW pieces.
