HH Servo
I'd be in for a few! :)
The one in my son's rig has been thru the shizzz..
A 10yr old. Crawlenhulls in CT, NENC, fishmax at World's, plus, plus, plus!
3 for the price of 1.. I'll throw 2 away for that 1 good one!
What do you need tested on them? I have been an electrical engineer for more years that I want to admit. I'll help out if your interested.
Just bench testing them. Cycle it back and forth with load, does it work, is it quiet, etc... We have a few hundred to go through, it's not difficulty of the task but time. While short staffed, we are doing well to just keep up on regular order fullfillment and customer support. If anyone notices, we have been out of BR mini duals for a while. Not because we don't have them, but because we can't build them fast enough to keep them stocked. Having one worker on vacation for a few weeks starts to add up!
I would be in for a few...the one I do have performs awesome (knock on wood!) Could you post here when they get added to your website so I don't miss out?; please and thank you.
Let me know if you do. I'll be home the next two weeks without much too do.
Count me in. I'm happy to help liberate you of dead stock anytime, lol. I finally got around to installing the 2 "blem" Trailmaster BL motors that you cleared out a while back, and they're great (esp. at the $35 price). My 400s have held up just fine, so these will make good spares until I can get my hands on an 500 or two. "thumbsup"
I look forward to the new servos! If they prove to be reliable, they will end up in all my rigs. :D
I've been trying very hard to break the new design, and I keep breaking everything else instead. Main test rig is a Wraith with alloy knucks and chubs, all ti linkages, and a Puller Pro 540 3500kv on 3s and stock gearing. I spent about 10 minutes driving sideways into pallets at 20mph, stripped out servo horns and bent plastic wheels. 10ft cliff dives into 20 more feet of cartwheels didn't work either, just broke links and ripped wheels off the hubs. I'm sure I could strip a gear with aluminum wheels and 20mph crashes if the horn didn't strip first. I need 7075 horns!
I want to test one!!!
540XL 3500kv on 4s.. I can slam into stuff ALOT faster! :) (32+mph)
Send one of them 7075 horns along too... [emoji106] [emoji41] [emoji108]
John.
When your kiddo Is a bit older you will have your product testing department! Mines 4 I'm amazed at what he brakes.
I've had good luck with robitronic(sp?) clamp on horns. The hitec 7950 in my wraith eats horns for breakfast until I tried these. So far so good. Maybe we need a Holmes produced line of servo horns? ;)
Really? I'm surprised.. I was all about robitronic's, till I couldn't keep them from striping..
They are only splined half the depth of the output gear mesh..
I switched to AHZ clamping horns.. They are basically identical, but splined the full depth..
Since then, I snagged up some ANSWER horns... Non clamping... Low profile/low sitting... Beef!
