Postclanker
Thanx man"thumbsup"
Here s the measurement u asked: front 11.5'' and rear 11'' outside tire to outside tire... Is that what u wanted?
That was it, thanks
Thanx man"thumbsup"
By the way Dan (Hulksta), do u have the measurements of all the hardware on the chassis? Would like to order some blue anodized harware for it... thx
Your smash looks nice and small "thumbsup"
I thought I'd put mine behind the rear window....what's your plan man ?
Mine sits like yours now Noname
I think yours is a bit lower even....my shocks measure 83mm eye to eye with an internal limiter (3mm) 40wt oil and the softest Losi Mini-t spring I can find (pink). Still playing with it. I'm not sure I want to limit the shocks any more, or use a different shock shaft to get it any lower, already at the limit with the shock mount locations.
I think my goal would be to get the top of the cab to be sitting below the top of the wheel at rest...
What are those front shocks Noname? And do you know what their length is?
Want to know where you plan on your electronics also....
Looks great Noname "thumbsup"
any updates? i just bought a riddler single shock mount but no shock and looks like stock scx 10 deadbolt shock is a bit long even fully compressed?
awsome rig has bergs and only complaint so far is gc is way less than mantis on xr and mantis on bully's but hoping once i get cab shock in and center pivoting clearance improves. now come on with the build "thumbsup"
With the single shock mount, this is an earlier chassis. The shock needs to be around the 55mm length eye to eye
