Ca. Off Roader
Sorry if this is a basic question but after searching around I learned a few things....
1) You can buy special pliers and other tools to install the ball into a ball link. I've always just used regular old pliers.
2) Some ball links are designed to have the ball installed from only one side. If you install the ball from the wrong side, it will stretch the socket & damage it allowing the ball to come out more easily than normal.
So my question is...
Is there a special way to install the ball into the Vanquish ball links?
I tried using a small pair of pliers and it wasn't big enough to push the ball into the link.
I was thinking of using bigger pliers but decided to check online in case there's a better / proper way to install them.
Thanks!
Thanks!
