So here is what it started out as. Really rough and ugly. I ran this chassis for a year and a half now with good results.
But I wanted to bring it to life so I reached out to Robbob (told him not to laugh) with the idea but it needed to be fixed up, cleaned up and a Krazed touch put to it. So I sent it to the Krazed Builds lab…and here it is, the new “Un Stuck” Chassis from Krazed Builds. Showed up last night along with my smash plate and this thing looks awesome. Rob designed to skid to work with a Hulksta transmission or an Axial transmission.
Specs for my new ride:
Front Axle:
SCX/AX10 Axle housing
Creation Fab Brass/Delrin tubes
Custom Smash Plate
VP Wraith C’s
VP Wraith Knucks
RCBros Knuckle weights and Holders 2.2oz per side
Axial 36/14 OD Gear
Axial XR Universal Axle Shafts
Grip Fab Locker
AVID Bearings
TI Drag link and tie rod
Rear Axle:
SCX/AX10 Axle Housing
Duuuuude Link Mount
Creation Fab Aluminum/Delrin Tubes
Axial 43/13 UD Gears
VP XR10 width Axle Shafts
Grip Fab Locker
AVID Bearings
Transmission:
Hulksta
Axial XR10 Internal Gears
AVID Bearings
Chassis / Suspension:
Krazed Builds "Un Stuck" Chassis
Custom Krazed Builds Delrin Skid & CF Adaptor plate for Hulksta Trans
Aluminum Cross Members
Egressor Shocks with Mini T springs and Jeepindoug spring cups
30wt Shock Fluid F&R
Gunnar body Mounts
TI Links all around
Traxxas Max Shafts
Electronics:
Holmes 30T Flow Motor
Castle Micro Sidewinder ESC
Hitec 7950 Servo
Castle 10A BEC
Futaba RX
Futaba 4PL
Rolling Stock:
Crazed Builds 3pc Snowflake CF Wheels
225 Hubs rear
850 Hubs Front
Ottsix VooDoo Tires. (Narrowed & Trimmed)
6”CI DD CC Foams (Narrowed)with soft ring up front and med ring out back
My Box O' Parts. Some New Some Old
So first thing I wanted to do was get the trans installed and make sure it all lined up.
Fit perfectly "thumbsup"
Thats all I got done last night. Hoping to get the axles buttoned up tonight.
Front Axle:
Custom Smash Plate
VP Wraith C’s
VP Wraith Knucks
Axial 36/14 OD Gear
Grip Fab Locker
AVID Bearings
Rear Axle:
Duuuuude Link Mount
Grip Fab Locker
AVID Bearings
Transmission:
Hulksta
AVID Bearings
Gunnar body Mounts
TI Links all around
Traxxas Max Shafts
Electronics:
Hitec 7950 Servo
Castle 10A BEC
Futaba RX
Futaba 4PL
Rolling Stock:
225 Hubs rear
850 Hubs Front
