vanquish threw off my yeti!!!help a newb!!plz..
kyle abbott
USA
I need some help!!!!!
I hit a rail road tie with my Yeti and broke my c-hub/caster block....whatever theyre called
so I put vanquish caster blocks.
now my front wheels are slanted like a "V". the tops of my tires are further out than the bottoms. I cant adjust them because the links are plastic....and shit...I heard you can use traxxas parts but I have no idea what to get because this is my first car, I just got it, don't know anyone that has rc's, and live out in the boonies.....being that I don't know what the parts are called I cant find a thread, and don't want to buy the wrong part so if you know what I need to do or know how I can fix this problem, please let me know.
oh one more thing. can I put steering knuckles that are a different brand like strc with the vanquish caster blocks?
Sounds like you have something installed backwards or upside down. The "C" ("CHUB" or "C-Hub") has one arm longer than the other. Longer should be on the bottom. post some pics if you can't figure it out, so we can see whats happening.
Can you move your plastic camber link to an inner hole on the shock tower? Or the inner hole on the c-hub? A pic would be worth a thousand words 8)
no theyre on right. I moved the link to the inner part of the tower and that worked somewhat. ill put up a picture now. its very slight but when im driving it I can tell.
To get a picture to appear, upload to photobucket. Then copy and past the IMG code in your forum post.
You can not post an attachment because you are not a star holding member of the forum.
Is that also why I cannot post a avatar?
