1/35 4WD FORD F-150 DIY SET (New Product Preview)
Higher number, higher speed (according to other posters) couldnt verify it personally yet.
As all my orders are still in transit.
Yeah that's right. I got the 300 and the 150, the 150 gives awesome crawl speeds and the 300 is a little quicker but nowhere near as much torque.
Ok. I guess I have the 120. I drove mine for the first time on my spot I have for the Losi micro. for the size this truck goes awesome.
:!: desperately needs more wheel speed and taller tires. I am for sure getting the alloy axels to help with ground clearance. any little bit will help.
So where is all the build pic being posted for the orlandoo? I want to see what ideas people come up with on this little truck.
I build wrangler rubicon on the parts Orlando and CNc axles.
but I can not paste the photos here
I got the pics to open. looks good.
what are you using for a trans?
assembly car
I reminde, open links in new tab
qZLQfjr-oEepZ
avQjVEFpoEevR
_rbmAY0xoEf4N
lU5SHDxwoEfEU
gWVVxjVjoEfLG
BMndQyF5oEfRE
rogkJLqFoEfZB
Ok so I received the linkages that are supposed to go with metal axle set but they're too short!
So I've got stock links which are too long and new ones which are too short. I just can't seem to work out why the metal axle set changes the geometry so much. If I set the lower links to the approx correct length the upper ones are way off and vice versa if I try the other way round.
I'm not sure how 'out' the axles are supposed to be from the middle of chassis, in other words what angle should the shocks be at...? Vertical or bottom of shock slightly further out than top I guess.
Can someone do me a huge favour and measure their links from inside ball end to inside ball end.
I've built literally hundreds of RC vehicles but this one has got me stumped!
Some quality issues.
So I kinda like this fiddly little car, and was mainly expecting problems with the kit itself.
Sofar not much to complain there.
On the other hand the electronics.
- ESC from HK, had to correct the soldering as + and signal on the servo plug were connecting
- Servo from BG, loose wire inside the servo housing.
- N20 120 rpm motor from BG, pinion was loose on the motor.
Solved but its all so tiny.
Next is getting it all together inside the car hope all stays intact.
Thanks joely. So the ball ends are covering all the thread (Ie wound all the way in?)
No, not the top ones. They have a few threads. I have covers on my bottom ones so can't really tell but pretty sure they're the same deal.
I wanted to build another one of these with a losi esc/reciever combo but the servo transfer lines that drop the voltage are no longer being carried by banggood, and I can't find any more in stock. I'd rather not try to make my own- I don't know anything about capacitors or where to put them. Anyone know a source or have one laying around you'd like to sell? Thanks
