Brake Weight
Sweet interior. Howsabout a LxW? I think it'd be more pleasing to the eye without the rear half of the cage.
Thank you for saving me the bucks Jeepiac. No GOM for me!
Yeah working on the electronics and tranny will be harder and require disassembly, the axles and suspension at least have easy access.Every little repair is going to entail pulling the whole thing apart.
Horrible wobble of the spur, Motor plate wont lock into place, Lockers are a cruel joke and here we are in 2017 and Gmade cant design a fawking axle that has anything that resembles steering without spending money and modifying of their parts.
Funny how Gmade happens to have so many upgrade parts already for something so new. Makes one think they may already know most of the defective points of the HOS. (hunk of shit)
Why address the flaws of a newly released kit when you can make money off the poor suckers that jumped on the wagon and blew $330 on it.
The spur gear wobble and motor plate issues are unfortunate but I feel with a bit of tinkering a fix can be found. Lockers and lack of steering, another issue lots of other RC's need help in improving, I see nothing new here.
Upgrades? are you really mad about upgrades? Almost all companies do them, and to throw all of the upgrades in would be lovely but that's not gonna help the kits price point any. I dont know if we've seen these "defective" points highlighted yet just people looking at parts saying oow that doesn't look strong enough, lets wait and see what parts are truly hunks of shit before calling it.
I understand all of your gripes with this kit. I hold none of them against you.
I will say, my yeti had a wobbly spur and so did my ascender and twin hammers kits. I was able to fix them luckily.
As for the GOM. I put a 5x11x4mm bearing in place of the 1150 bushing and that actually helped a lot. But mine wasnt overly wobbly to begin with.
I still havnt run it though.. I take forever on building kits as it's my favorite part. Paint alone will take weeks with all the taping and design.
My upgrade parts will be here on Monday, But none of them are performance enhancing parts... because those arnt available yet.
I didnt have the motor mount issue that you had. Mine is locked tightly. Actually, just fitting the plate in without the clamp held it almost too tight to move.
Definitely not arguing, just reporting my experience so far.
I feel for you man, truly.
Wobbly spur is unfortunate? It's unacceptable to say the least. Why should I have to tinker with something this basic to make it right?
All R/C need improvement out of the box, but fixing actual factory defects and poor design that the manufacturer is clearly aware of is BS. Upgrading is normally done to improve performance and durability, not to fix something like a motor plate that wont hold the motor in place.
You're right, I guess its easy to look at the bright side when I dont own one.
I have been setting here watching the boob tube and me being me, I cant not tinker, so I've been addressing some issues. Filing of the clutch plate where sets against the inner race of the bearing has helped with wobble, but the generally loose fit over the input shaft still allows a little wobble. I think it's going to be a little noisy, but still better than my super shafty transmission with the 32p steal spur "thumbsup". I also did some light filing of the motor strap and the case where they both meet. I can still twist the motor, but it takes a lot of effort. Hoping it holds and I don't have to buy "upgrades" lol
I tightened the strap all the way down till it met the plastic part of the motor mount. No gaps at all and the motor would still rotate rather easily. I removed a small amount of plastic from from the strap and plate where the hold down bolts go through and then tightened it like I was going to kill it. One thing about it, the plastic will hold threads pretty dang good. Anyway, I think it will hold the power I'm planning on running without any trouble now.When you have the motor strap on, does it meet the plastic motor plate on both sides?
I had the same issue as you, the motor plate feeling tight but being able to rock it out of mesh by hand with sufficient force. The pot metal plate on mine felt like it was seated properly, but I had gaps between the plastic motor plate & the strap. I didn’t want to cinch down too much for fear of stripping the plastic threads. I finally worked the bolts down so that the strap met the motor plate on both sides, the pot metal plate worked it’s way down & seated properly. Now When seated but not tightened down The motor is tough to move but able to move in & out of mesh, but won’t budge with the strap tightened down.
