Class 1 - Details:
• Vehicle must utilize a Chassis Mounted Steering (CMS) setup.
• Vehicle must have a windshield that fills the entire windshield frame.
• Full width bumpers are required on the front and rear of the vehicle. Bumpers that are molded into thebody
qualify. A rear bumper is not required on a flatbed, but adding one to the flatbed will gain the additional
scale points. (Bumpers are measured from the outsides and must be the width of your windshield).
• Wheels must be aligned within the body wheel wells (center of wheels to center of wheel wells +/- 1/2 inch
total combined)
• The vehicles body must be mostly intact. Only mild trimming is allowed, such as removing: flairs, trim,
molding & a hardtop. If the hardtop is removed, a full interior is required (no extreme trimming of bodies
allowed *See below.)
• Bodies should be mounted in a realistic position in relation to the chassis (like a 1:1 would be).
• Any removal of material from behind the front wheel well (except trim/molding) is considered a boat side.
• Boat sides are not allowed.
• Dovetailing is not allowed.
• Sectioning or narrowing of the body is not allowed.
• Bobbing a truck bed is allowed, but must follow all body specs.
• Sliders must run parallel to the factory rocker bottom.
• The tread of the tires cannot extend outside of the wheel wells more then 1/2 of the tread width, flairs canbe
added to reach min. spec.
• Vehicle must run a full length rail chassis (The rail chassis must be as long as the vehicleswheelbase)(Tamiya
CC-01 chassis are allowed).
• *For 2018, you will be required to run a metal rail chassis AND parallel skid plate in class 1.
• Truggies are not allowed, flatbeds with full length rail chassis are allowed. The bed must be as wide as the cab
the entire length of the bed. Cab only not allowed.
• Tires can never extend beyond the body’s bumpers or the rear of any truck bed. (Any stingers,fairleads,
shackles, bolts, etc. are not considered part of a bumper when determining this.)
• 106mm / 4.19" Max tire size including spares.
• Gates will be a minimum of 11" wide (so mind your width).
I'm sorry having to ask this, but I'm trying to get back to the scale crawlers from a long period out of the hobby altogether and I'm looking forward, now that I live somewhere with a lively scale crawler crowd, to get into competition, so I don't understand some of these in-house terms used in the rules.
1- What are sliders?
2- What are Parallel Skid Plates?
3-Does a Gelande 2 D90 fits into the Metal Rail Chassis description?
4- Btw, what is a Dig that everybody's talking about?
5- Is the RC4WD MTZ 4.19 considered a class 1 tire?
Cheers
