3d printer for rc parts
That is is true. With the layer having a round profile on top you get less contact between layers and less strength. I traded off strength for maximum clarity which is ok in a vase.
If I was wanting a stronger print I would use a lower layer height and more layers. But the plastic would have a cloudy look to it.
Another factor is the plastic being used, since PETT is "sticky" when hot, you have a higher layer height and still get bonding of the layers.
A nice thing about 3D printing is you never run of things to learn due to all of the different options that are available.
I'm not familiar with PETT.
PETT is another variant of PET and is known for being clear. The most common brand name is t-glase by Taulman 3D.
It is similar to PETG but isn't as flexible. It is popular for trinkets and vases but you can actually print light-pipes with it. It also works well for scale light lenses.
This link has all kinds info on it: t-glase Features
Getting the PETG hang
Hang up and Drive
Boy did that picture suck !
Early morning and low light. Got home today and trimmed and fit it into OPIE , looks good, need to make a couple of straps from aluminum . Then into the paint booth.
Hang up and Drive
That looks great, I want to do a fuel cell like that soon too. I'll be slicing the cap off mine so I can paint it easier. I also want to do a radiator, fire extinguishers, seats, etc lol.
One cool thing I found on thingiverse was a copy of a Wraith wheel, complete 3-pc design. It was kinda poorly done & I spent HOURS perfecting it. The initial PLA version is plenty strong, so the PETG ver should be great. I also want to adapt it so I can put a dualie version on a future project.
need to go glass plate soon for PETG.
I found PETG sticks to kapton tape perfectly, and I got a huge roll of it for $16. I've also never needed a raft for PETG either with kapton nor blue tape, maybe your bed isn't hot enough.
If youre still shedding stringies you could try slowing the head down or turning your fan down. Im at 75% right now but gonna try dropping to 50%, I get some layer splitting. Also restraction can help too with getting rid of the hairies/stringies.
PETG should not be run with ANY fan on, it doesn't warp like PLA. The cracking is from it cooling too much as it's being laid down and not melting into the layer below. You may want to increase your extrusion temp too.
To avoid those strings I increased the retract distance (how much it sucks back into the head) and speed to almost double that of PLA. You could also try a longer "coasting" length (last few MM it lets it ooze out). This is especially true if you increase the feedstock multi for PETG (usually 100-110%) whereas PLA is usually ~90.%
Sticking and warping aren’t any problem, sticks well. I’ve also found 245 /75 and 20% fan work well on PETG, I’ve messed with retraction and speed, not lots of difference though.
Hang up and Drive
Here's another thingiverse item I'm messing with, I'm in the process of slicing it into individual pieces & panels.
What software are you using to split it? I've been updating/changing, a Splitwindow Bus file and have a bit of an issue with Meshmixer. Makergear M2 printer
What software are you guys using for sending parts to the printer? I have a Macbook Pro and am curious if the software will work on it. Not much 3D modeling software is compatible with Apple :cry:
Cura converts the solid models (.STL) to GCODE that the printer can read. Does that answer your question?
Got it! Watched some youtube videos on the printer. Looks like I can run Google Sketchup with the STL file extension and be able to design and make my own parts... "thumbsup"
Google Sketchup and TinkerCAD are good starts, but they're not that powerful. The link below will show you free ones for OSX. Also checkout Fusion360. That's powerful and free, but I'm not sure if it's available on OSX.
https://www.shapeways.com/creator/tools
I got into Blender (free) for editing STL's and MakerBot for printing specifically for my printer (QIDI Tech, Replicator clone). Blender isn't exactly intuitive, but there is a TON of vids & info on the net. I'll have to give Fusion 360 a try though. Also been meaning to try Cura & Simplify3D, both are supposed to be great.
