I use the team associated driver set. Worked fine for over a year now. How ever my 1.5 has twisted from applying to much pressure. Still works tho.
Dynamite has a set just like this now. I also have been using an additional dynamite set that holds all the drivers in the handle for the last 7yrs. No issues yet with either set.
"thumbsup"I've had a bunch over the years. Consider things that you may or may not like... things like shaft length, magnetic or non-magnetic tip, handle diameter and shape ( round handles can be irritating as they easily roll off of tables), ball-end tip or box tip, replaceable or fixed shaft, and hex material. Quality durable drivers are worth the money imo even though they're going to generally cost more.
My older Hudy, MIP, and Dynamite hex drivers have been my favorites. Least favorites have been my ( also older) Great Plains, Hobbico, and Duratrax brands for one reason or another.
I've got 2 sets now of like 40 or 60 bits just because those same sizes mainly the 2mm get worn out. I've tried searching for some titanium ones but can't find anything.....I’m looking for some decent metric hex Drivers 1.5, 2 and 2.5mm basically. I have a cheap duratrax tool set that I’ve already worn the tips out of them. Any suggestions? Thanks
Seen a guy on facebook post this set hope it helpsI’m looking for some decent metric hex Drivers 1.5, 2 and 2.5mm basically. I have a cheap duratrax tool set that I’ve already worn the tips out of them. Any suggestions? Thanks
I use the MIP speedtips, so far 0 wear, and 0 stripped screws.
with my dewalt screwdriver (best christmas present ever)
For manual stuff I have a screwdriver handle. It also holds six long bits in it, which is convenient for when I go trailing, as I only need to bring two tools.I use MIP speedtips with a Bosch screwdriver for the most part. For manual hex drivers, I use Wera (most comfortable handles on drivers I've ever had). I've had associated in the past (still do actually) and the aluminum handles are ridiculously uncomfortable when having to use more than minimal force to loosen something.
Dynamite makes a couple sets, so for those who are recommending the Dynamites, it would be most helpful if you mentioned which set.
WTF? Those tools are less than a year old. Did they replace it?VP, I have broken one 1.5mm tip so far.
