Hi,
more goodies coming!
after the motor mount, I want to make the truck standing on it's own so the work order is: front axle truss, panhard and upper link and spring/shock mounts
The truss:
Started with the axle springs mounts, similar to the 3d printed i have in the back but in steel to be welded
Added a 5mm square steel rod,tight to the housing
To finish, the panhard mount next to the knuckle and the angled upper link mount
The idea behind the truss was making it low profile so it wouldn't hit the frame rails but in the same time, looked from factory. The angled link mount allows to use straight rods and has a thread to avoid the "nut and bolt"
The truss:
