OzarkCrawler
I do have the gaskets installed. I'll try loosening things up. Thanks bro. "thumbsup"Wait a sec, I just had another thought, If you used the HD lockers which I think you did, you do need to use the Differential gasket (GM60028 ) that goes between the ring gear and the locker (used on the stock parts), I believe leaving this out puts the gears a bit too close together. When I put my lockers in I tried it without the gasket not knowing which to do and it was too tight.
