Can't you turn down the Jerk speed in the firmware?
Yup found that today, turned it down in half and much smoother without loosing speed.
Even set the bios to give me an Autotune PID on the screen. "thumbsup"
I found this one on Amazon https://www.amazon.com/gp/product/B07B251KBS/ref=ox_sc_act_title_1?smid=A13LEXACEUFXQ2&psc=1 the description say they have the plates for other printers too.You need to get a new aluminum or composite bed plate. The stock stamped one warps. Mine is almost useless, I’m way down to a small adj in one corner. I’m planning a bearing and bed upgrade when I can FIND the bed in the USA, most are not here, shipping is sketchy now from HK
Hang up and Drive
I'm going to order it and see what it looks like. Was $27.99 Prime
I'm having an issue keeping my bed level. It will level fine in the LR & RF but the RR & LF I can back the screws all the way off and it still won't put any drag on the noozle. The Z rod is parallel with the bed. Had this issue once before and I took the heat bed off and put a straight edge on the bottom plate and it was not straight. Pulled the corners up till it was flat and all was well for a little while. Didn't take it apart but I'm almost sure that is what is wrong again.
I'm thinking I should make some stiffeners for it or get a different plate. Is this a common problem with PowerSpec Duplicator i3 Plus (Wanhao Duplicator i3d Plus)?
Hang up and Drive
My prints just went to shyte. All was good until I updated to cura 3.3.1. Even with it importing my settings, prints started look like they where printing using larger layer heights and the layer where not adhering to each other.
I check everything that against what I had written down and they where all the same. After being pissed for two days I upped the temp by 20 degrees to 220 and prints are back to where they were.
Anyone else have a cura issue with the upgrade?
Yeah I see the fan settings. I've unchecked cooling and it doesn't stop the fan. Beyond that I haven't played with it.
Did you import the profile from your older Cura? I had problems using the newer Cura's for a while, I always resorted back to 15.04 as my safe versions.
I did switch last night to the most current (3.3.2 I think it was) and imported my profile I know works good. I did some tweaking on the newer settings and printed a few parts with good success.
Could also try a temp gun on your hotend, see if its telling the machine the correct temp or try doing some PID tuning.
I learned to back up my config. I’ve always done custom, Now with all set, I change temp for different filament automatically by setting proper profile. Temp and feed are critical, calibrate estep and due PID autotune.
I print PLA at 205, PETG at 235.
So 220 isn’t all out of line.
Hang up and Drive
Hmm...I wonder if something like this is available for the Monoprice Select Mini. Sometimes I think my bed isn't flat. I'm not going to glass.I found this one on Amazon https://www.amazon.com/gp/product/B07B251KBS/ref=ox_sc_act_title_1?smid=A13LEXACEUFXQ2&psc=1 the description say they have the plates for other printers too.
The autotune if correct should stop that swing. Mine has 3 settings depending on temperature I want to use. When doing the autotune do it 8 cycles or so.
There are two different autotune commands, one for hot end, another different for the bed. You need both
Hang up and Drive
I ran autotune for both at the temp I run pla since that's the only thing I'm playing with atm. Last round I did ran 25 cycles on the hotend and 15 cycles on the bed. Also made sure to M500 after tune was done.
Fan set at 100% manually before running autotune? it does make a difference.
