Foxtrot121
As the title says, I just installed the traxxas long arm lift kit for my trx4 and my steering horn is binding on the track bar. At rest on level ground I have maybe 2mm of clearance between the two. More clearance when I turn hard to the right, and even less when I turn to the left.
I have a Savox sw-0231mg servo and an axial aluminum clamper steering horn. I took the horn off and I have a little bit of clearance with the track bar. Maybe a stock plastic horn would fit? Unfortunately I binned mine when the stock servo died.
I have a few photos of this in this gallery. https://imgur.com/a/2C68pPg
Can anyone make a recommendation on what I should get to fix this issue? Swap back to a factory plastic steering horn? Swap for a factory/shorter steering servo?
A gentlemen in the newbie section suggested I ask here.;-)
EDIT: See post #11 for updates
