Nabil
no talent hack
Locally there have been a few different scale comps popping up which run standard rules but without counting scale points. That combined with the intro of the new performance scale class that was ran at worlds has prompted me to build a new “class 2” truck. I’ll be keeping my current C2 truck for general driving as well as comps that do count scale points though. Build specs to follow
Axles:
Scx10 housings
Brass narrow xr beef tubes front
Brass tubes rear (undecided if they will stay)
Brass Dlux knuckles with tungsten slugs and cf arms
Narrowed xr universals
Vp c hubs
Locked up rc spools
OD/UD
Dlux trusses front and rear
Driveline:
Dlux hamberger
Saf gears
Ti shaft
Sdi 5mm prop shafts
Chassis:
Team gspeed v2
Strc rear honcho cross member
Crc front cross member and bumper
Rpm sliders
Suspension:
Traxxas 2660 big bores with cap mod
Ti upper and lower links
Tires and wheels:
Ottsix gold voodoo klr tires
Crawler innovations 4.25 foams
Vanquish knockoffs
Electronics:
Team brood vigor 4 pole motor
Castle micro x crawler edition
Hitec 7950
Removable low profile winch servo/LURC spool
Castle bec
Futaba 4pv
Axles:
Scx10 housings
Vp c hubs
Locked up rc spools
OD/UD
Driveline:
Dlux hamberger
Saf gears
Ti shaft
Sdi 5mm prop shafts
Chassis:
Team gspeed v2
Rpm sliders
Suspension:
Tires and wheels:
Vanquish knockoffs
Electronics:
Hitec 7950
Castle bec
Futaba 4pv
