Yes, you can limit max power in castle link. About 75% would be the speed you want.
I got one, cracked it open and coated the board liberally with conformal coating. It should be pretty easy if you are careful.I picked up the non waterproof TrailMaster BLE Pro. How hard would it be to waterproof?
Brushed I would select a 550 21t. Brushless, 2700kv would be near stock speed I estimate. I almost always use a 3500 Puller if not a 1800 revolver for my personal single speed builds.
I have a 2700 Trailmaster and BLE, it similar to stock, but I'm still fine tuning to get it how I want it.Hey, got my Gen 8 scout and am wanting to get a better motor than the stock one. I think the stock one is 17t and was trying to decide between brushless and brushed. I was thinking a 21t torque master expert or pro would give me more power and torque than the original pus slow it down just a tad
the other option was maybe a BLE and a 2700-3300kv trailmaster pro or a 2700-3500kv puller pro...any suggestions?
I checked it all out, it is green forwards and red in reverse. Recalibrated multiple times, still takes at least half pull to get forward and barely anything to go in reverse. Also seems to be much faster in reverse.Sounds like you have reverse and forward backwards. When accelerating the led on the esc should be green, reverse is red. Check that and if OK. Recalibrate your controller to the esc
Hang up and Drive
So I played around with the PWM frequency, it seems that it is only doing it when I have it set to dithered mode. Any other frequency, and it responds the way it should. Kinda strange, but if that's what it takes I will switch away from it LOL [emoji23]
Sent from my Pixel 2 using Tapatalk
Which cable, the sensor cable? No. Honestly I wasn't a huge fan of dithered mode anyway, so it's not a big loss if this is what it takes.Did you try another cable ?
That’s a new one.
Hang up and Drive
I'll give that a try, I've got plenty of time while it's Sub-Zero temps again! [emoji1787]That’s very strange and I have no solution! Besides maybe rolling firmware back and forwards.
