utieh
I need some help with a problem I still can't figure out after months.
Thanks in advance for reading.
I started a build with SSD's Diamond axles.
From the very beginning the gears were skipping while hitting some obstacles:
- going forward, the front axle's gears skip
- going in reverse, the rear axle's gears skip
Separately each element runs smoothly (transmission, front axle, rear axle), drive shafts do not bind.
I ordered some shims to reduce the play and the problem persisted
I added more shims till there were only 0.5mm of play on the pinion's shaft
I also installed new HD gears (Axial) since I started to see some wear on the original one (also Axial HDs).
Still the same, and it gets worse with time (end of the 2nd battery pack)
I thought the SSD axles were the problem so I ordered a set of new stock Axial axle casings (first gen).
It's a little bit better but I feel it's going to get worse like before.
Any idea what the problem could be? Anyone had experienced the same thing?
Thanks,
Gilles
Thanks,
Gilles
