utieh
I think I found the solution, I was shimming the pinion gear inside the axle, the 2 axles required a different amount of shims but now the clicking noise is gone, at least when I turn the wheels manually, no more locking as well.
I'll do a real test on the trail and keep this thread updated.
Thanks for your help and input.
Are you shimming the same amount as you did with the last housing? I ask because each housing is likely to be different.
I'd try loosening it up a bit to see how that feels.
Also where are you shimming? the ring gear, pinion or both?
I dont have any experience with the original SCX10 axles but I've done 3 of the 10.2 axle sets. I dont think I've ever had to shim the pinion its always been the ring gear which means very little since its a different design, just an example I suppose.
