Is there any consumables that these printers need? After buying one what all would you need to use one?
I’m not sure if this is the right place to post but I use a Modified Monoprice Maker Plus (Wanhao i3Plus). I typically use PLA+ filament because it is easy to use and prints so nicely. The problem is over time I feel like parts become brittle. I have a heated bed and Micro Swiss hotend but no enclosure. I like printing pretty elaborate RC parts. Like transmissions, shock towers, etc that require decent tolerant and fitment. My question is what filaments have you used with a similar printer with success?
If you don’t mind me asking, what brand of PETG do you like to use? I have used it but it but it doesn’t seem as clean at PLA. I would like to try it again.
I use the same printer and have had great success with carbon fiber infused PLA. If you use it though, it's a good idea to get a hardened nozzle.
https://www.amazon.com/gp/product/B01KWVOFD4
I think your shackle needs to be moved forward or the leaf suspension won't flex properly.
The rear shackle, yea.. I will check on that. Thanks
The trailer looks awesome btw! I only have black petg for my printer so I gotta buy more colors so I can actually make stuff like this.
New printer, New filament for a new decade.
CR20 Pro, ProtoPasta HTPLA
Prints like a dream, with The latest version of Cura(4.4?) If you use a Creality Profile, it will have “dynamic “ layer(.16) and (.20) normal, the quality the dynamic layer is phenomenal! In a nutshell, it’s the “Creawesum” mod from before, and it works well.noticeably smoother on all printers, by looking at the profiles.
My older time learned and tweaked profile is almost a mirror of this OOB profile!!! Wow!
Hang up and Drive
Print it gussets down, rotate 90.
My new printer is an Creality CR20 Pro
I grabbed it for 299. At AMain.
24v power supply, auto leveling, a bit smaller than the CR10, and bigger than the 3 all metal, solid and quieter than my III plus. I did print a wad of those, different infill, for heat treatment.
Last night I did my old standby the Benchy, in dynamic mode. One minor bridging flaw in the arch. I will post some pix up when home.
Hang up and Drive
