I finally had some time to continue with this project
this is going to be about how I build the rear roll cage for this rig
My initial intention was to replicate the "Team Jccmog" Unimog but the wheelbase on my chassis is longer, so the original design of two straight rear bars look awkward on my model
So I thought about adding a rear winch to fill the space so now I have to design and build a custom real roll cage
first I built the structure that fits in the back of the cab
then I build the back cage support, this part includes the winch line fairlead and the mounts for the
Powershift RC Technologies PST Flush Mount Tailights
then rear roll cage is going to have 6 support plates, 2 in the front 2 in the middle and 2 in the back
the BPC GenX Steel Rail Chassis has several mount holes, so I can fix the roll cage on them
Now that I know where the supports are going to be located, I can continue with the brazing
to avoid offsets in mounts I decided to fix the lateral plates to the chassis and the braze the roll cage. I noticed later that the powder coating applied to the chassis was a little bit burned, also a couple of plastic rod ends were burned but I can replace it later
fortunately, after the brazing the fit was perfect.
now let's braze the front support for this roll cage.
In my opinion, the most difficult part is to build the parts prior to brazing. you have to make the parts fit properly before brazing
notching the steel rod is difficult if you don't have the right tools, I am working with the following tools
I have to find a wat to reinforce the structure so let's build a couple of lateral supports
after this, I can finally braze the long rear bars
Now I can add some extra supports and details including the fairlead for the rear winch
I am going to use a different steel rod diameter for the winch hook holder and for the upper lift plates where I going to install a pulling strap
finally, let's build a different fairlead for the rc42w winch
this is the final result
