Arctic Cat ZRT
Took last year off of crawling/trail runs to get into 1/14 RC construction equipment (if you thought crawlers were expensive... :shock
. My wife and I got a puppy so we know we will be hiking a lot more, decided to get the trail rigs back ready.
The Unimog was in desperate need of a rebuilt/revamp. As I disassembled the truck I realized how bad of shape it was in, gotta step up my routine maintenance game going forward. Figured I would try and document my rebuild starting with a pre-disassembly pic and build scope. Build will consist of some new parts, some used parts, and some spare parts from old builds. Might also get around to installing portals if money allows.
1. Install HH Brushless system from my old wraith
2. New Incision slipper eliminator and Incision SCX10 tranny output set
3. HR 56 tooth 32P steel spur, RR absolute hardened 9 tooth pinion
4. RC4WD punisher steel drive shaft from tranny to transfer case
5. Axial spiral bevel gear set and Incision spools
6. MIP wraith drive shafts (if they fit)
7. New CI single stage foams and Fresh RC4WD ground hawg II tires (tires are pretty close tread pattern to the agriculture tires that would be on this thing IRL)
8. New HeyOK light controller, headlights, and light bar. New LED harness
9. New bearings, hardware, shock rebuilds, etc.
10. Repair/refresh body and add a few more details.
11. New complete frame/skid plate
12. Redesigned bumpers front and back
