All of the parts got here last month so this past weekend I put the Bronco in the new garage and got the wrenches out. The full list included .... a new V2 BowHouse slid-plate, Jazrider steel drivelines, HR helical cut gears for both diff's (still OD and UD), all new Power HD mini servos and a fresh 46KG steering servo, and Xtra Speed rear shock mounts.
I LIKE the new skid'. Definitely improved the fit and finish. I still had to install the rear driveline to the trans' from the top, you can't get to the screw-pin from the bottom because the skid covers it, but no big deal. It's smoother and the link pockets fit much better now. The Jazrider rear driveline was a little too long for my rig, but the grinder "adjusted" it just right. The new keeper sleeves should be more trouble free than the spring coils, and they're nice and heavy hardened steel.
While I had the axles torn down for new rings and pinions, I figured I'd re-grease the gears. Then while the front was apart I decided to swap sides with the c-hubs. After reading a few other threads and studyin' a bit on steering geometry, I wanted to try eliminating as much caster as I could. Ended up just damned near zeroin' out. It seems to turn tighter now. The inner tires cut about a 20-22 inch circle now, with both diff's unlocked. "thumbsup"
Of course that put the shock mount holes on the front side of the axle, so I drilled and tapped some on the back side of the C's and voila. The extra holes are still there, but whatever. :roll:
The steering was really the only performance improvement. Everything else was just stronger or smoother, but didn't make it much "better" at crawlin'. It didn't really need new servos, but like the other stuff, I thought I'd upgrade the Bronco and the hand-me-down take-offs can go into the shorty build. I really like the Xtra Speed front shock mounts. The panhard mount is nice and beefy, so I got a set of them for the shorty too. The pull-off rears will be fine for now. The Xtra rears are beefy too, and they match.
I was thrilled after all the surgeries that everything still worked .... lights, winch and all the new servos are spot on. The new gears are smoother, and the skid seems to have lowered the truck's "voice". :lol: It still whines .... just at a lower pitch. :roll: :lmao:
Now Goof' and the pup are ready to drop it off of the stands and go find some rocks.
And I can work on the Shorty. ;-) Thanks for lookin' .... tune in next time.
8) jim
