Well, enough waiting around, I had to start the tinkering. Tinker I did, and will continue for some time. My tires haven't seen dirt yet, and it'll likely be several months before they do.
Speaking of tires, I started by removing the wheels. This required a 4mm nut driver, with very shallow walls to fit in the center cap's recesses. I had a 4mm nut driver that wasn't shallow walled, so out came the grinder. Now it has shallow walls, so I was able to remove the wheels.
That's a knock on this truck. It's lame that it requires a special tool, just to get the wheels off. RC4WD should have included a nut driver for that.
Having the wheels off allowed me to confirm that they are pin drive wheels, and there is a very easy way to change that. Axial SCX10.3 hexes are a direct bolt on. Then just add some hex adapters to the 6 bolt wheels, and you've now got hex drive wheels. You would need to drill out the lug holes in the wheels, and remove the scale brake caliper to make that work. I'm sticking with pin drive for now.
I also confirmed that each shock mount has room for a second shock. Not surprising as the full size truck runs 2 shocks per wheel.
Front:
Rear:
The only time I put power to the truck was to check if the differentials are independently lockable. For my purposes, they are. I used a white paint pen to make marks on the TX where the rear only is locked, and then another mark where both are locked. So you can lock the rear by itself, but not the front. For the front to lock, both have to be locked.
Next up, start to disassemble everything for paint, and rebuild with my Loc-Tite handy. Here's a few comparison photos with my SCX10 Bronco. Remember, the Bronco is 1/7 scale. They're a pretty close match. The Bronco is like a street legal trail truck, where the Miller truck is like its "off-highway" only brother.
Front:
Rear:
