I will say that in my opinion I think the 10mm hubs would look a lot cleaner, although it still looks sweet with the 12s (I personally like narrower offsets, I run 8mm hubs on mine). The wheel/tire combo looks great btw, fits really well with the rest of the build. Lookin good!
Glad you like it. I agree the 10 mm would be thing I'd like to try, or even 8 mm, but I don't think I have any around, at the moment. Tire offset is yet another (like many) feats that is so personal. I unglued these tires from the SCX10 II Honcho, since I have a couple of friends with the same exact tires. I am sure they are not the best performers in comparison to the other ones I have, but they have been basically never driven since I got the Honcho and replaced them right away, and they were new. They deserve some run time and they're the skinniest tire I have, I wanted to go skinny for starters, on this rig for this year
Looks good and having spent the last 15 years living in California and Colorado the extra wide stance is totally normal. Though I'm not sure the jeeps with super exaggerated width truly see much dirt, just pavement and parking lots.
On my scx10iii I've lowered them by using shorter 90mm shocks but also relocating the bottom mount to the lower link mount using a longer screw and some spacers. But it does open a can of worms for other clearances issues, like spring/sitting perch to the axle side panhard mount, tire clearance, and on mine the bolt holding the drag link bolted to the servo horn contacted before shocks bottomed.
Thanks! Glad you like it. I couldn't agree more as I have lived in CA and been around in the last years, too (never visited Colorado, I wish I had!) and the stance is totally normal. Also EQUALLY normal is: those very rigs are the ones who never see the smallest of pebbles
they roughest they've climbed is some multi-level parking lot at a mall
Thanks for elaborating on what you did on the shocks, as I have done almost exactly the same, verbatim: 90 mm shocks, gonna do a pen spring mod as well, mounted high on the highest of points, mounted low on the link mount, with longer screws and spacers. I've reworked things and so far I see no bindings, especially with skinny tires, but after the servo mod I am getting a lot more steering and with bigger tires I am sure I'd rub against the shocks. Or maybe not, we'll see. But you are right that it's not automatically done, it opens a can of worms with tolerances and bindings, but it's doable... it's a fun puzzle to solve. The rear is much easier, even with the anti-sway bar I built.
These mods are a must if you want the chin to be rubbing, and with straight axles, it's a bull!
I am still thinking the longer links I had made are going to be good because I don't think extending the actual ones will give me enough push. As I wrote, I want the front side of the rim 'circle' to be vertically aligned with the end of the fender, almost... not pushing the tire after the bumper
but a tiny bit of push. I had it that way with the previous build, and I did notice some better climbing, and the driveshaft was not at any weird angle. But mostly, it's a tad more aggressive.
I'll see if turning the stock links through their center holes will give me that much that is enough... turning them with a screwdriver will only need... 40 minutes
