west virginia krawler
Ok yall, for those of u that are making the redneck scale type of trucks or if you just want some humor in your truck heres a way to make your own truck nutz. Its pretty simple, ill try not to make it sound to perverted. Ok the suplys you will need is: Water baloon, 2 marbles, and some sort of lubricant. Ok here it goes, first you will need to put some soap (the lub) in the tip of the baloon, then slide the balls in the baloon. Then you need to suck the air out of them and tie it off. Then there you go. and the finial product.
