Double J
Nice post! This one should be stickied.
X2 stickie combined with the one I posted.
Wish my camera was as clear as yours."thumbsup"
Do you heat and apply silver brazing alloy to the other side of the joint? It looks like your only melting it onto the tubing?
I never could braze as good with the tubing laying on the table, as the metal it is laying on takes heat away from that joint...Also, looks like you could have "fishmouthed" the tubing better in that first and 2nd pic. Looks like to much of a gap on the inside "thumbsup"
Ok guys, I merged your 2 brazing video threads together and made it a sticky. You can keep adding to this thread with more tips/tricks. "thumbsup"
I haven't seen anything but 3/32 or 1/16. but it should say it on the canister in came in.
Well is it harris or something else. can you post a pic of what you have?
I've never had a problem with my unadjustable heating torch.
The only other time I use anything else is with thicker material that takes forever to heat up with just a normal set up. Then I use the mapp/oxy mix for higher heat out put.
I also try to suspend my pieces above my metal table so the aluminum doesn't take some of the heat.
