MaX-D
How much wider are the scx10 axles vs stock Barrage?
Sent from my VS985 4G using Tapatalk
My kit version came with plastic. Doomsday owners report plastic. I fully assume the Gen2 RTR is plastic as well.
A Google search turns up some evidence that the Everest/Temper was/is prone to the same failure.
Side note -- here's a guy who used glue to fix (maybe) as we've been discussing.
https://www.youtube.com/watch?v=QfAwKNJnuT8
Similar rig, same problem.
That's a 10th scale everest the locker is completely different.
But as mentioned jb weld might work.
These guys are lucky, the AL locker for that is dime a dozen on ebay. I have a spare plastic one from Redcat that I will be applying some JB weld or plastic welder. I just have not stripped out the stock ones yet!!!
i dont see the scx axles? I am seeing gen 1 barrage axles under the bronco. Am i missing something?
I just got hot racing spools and axial gears in mine.
Lhs owner said hot racing is working on the Barrage/Temper spools hmm
I opened up the axles last night looking for the source of play (spool) and the plan was to jb weld it if it has ovalized. To my surprise the plastic spools are mint and even when I shined a flashlight in the hole it looks good all the way through. Im sure the slop gets worse to a point but also if prevented might not develop into a stripped spool at all.
