NaZ-T
We just ran our last comp like this , this sunday. We only had like 20 drivers in 2.2 . Started at 9am was done with 2.2 at 11:30.
The system works !, Im sure once everyone sees how smooth it goes all the clubs will run the same way. ;-)
I like to call it the 801 format (seen how 801RCC started it) :lol:"thumbsup"
When we 1st switched to the "801 format" we were skeptical too. But after our 1st comp everyone in the club agreed that it worked out even better than expected.
The "801 format" allows you to pick what order you run the courses. So if there is a couple of real hard courses you can get them in early so you can relax a bit on the others, or you can run the easy ones 1st so you have good confidence for the hard ones. It lets the driver choose his plan of attack so to speak.The "801 format" also allows you to hang with who ever you wish. So if you and your buddies all want to run with each other then you simply line up together and you'll get to run 1 right after another. Also you can pick witch drivers you want to, because your not split into a group were you see the same people (your group) run all day and miss everyone else's runs.
Hope the "801 format" works for you guys it works real good for us.
Like PROTOTYPE said I think more and more clubs will start to use the "801 format".
