losikid
Got Worms?
Has anyone had experience with 3d printing (FDM type)
A lot of 3d printing I have been around, actually doesn't do many holes, if any at all.....they typically put a dimple where the whole is going to be drilled, or just the start of the hole, then you can drill them on a simple drill press if they want or a mill.
Later EddieO
Hi Losikid
I own a BFB 3000, which is an amazing 3d printer at relatively low cost. I am using it at the moment, to make my own crawler from scratch.
Normally i use the printer for prototypes, but its very handy for RC. I wouldnt say that the printer is bad for anything, it depends on knowing how to use it. But ofcourse, if you want an arm for a flux going at 60 mph into a wall, it will not last as much as for instance an RPM arm.
On the other side, if you use it for printing crawler parts, you can do anything - since the load on these arms will not be enough to break them (unless you let it drop from a mountain.. )
As for your radiobox, if you want it printed, and have a design then PM me here, and i will have a look at it, and i can give you a price quotation - it will be cheap ( think 50 usd max ) compared to what others will do, and for that price, i will print it in a PLA type material, which means it will be very hard to break. You will be able to spraypaint this in any color you want!
Let me know!
