What's the average runtime you get from that battery? Its not a Lipo, is it better than a lipo?
Is there a thread in here telling you the difference between the 2 ?
I don't have one, but a handful of regular Ascender guys have - and they love 'em.
Very good runtime is what I've heard - average runtime depends on too many factors to really say, vehicle type/motor kv (turns)/gearing, etc.
If you compare 2S to 3S batteries with the same mAh rating there is typically a noticeable increase with the 3S.
If you've got at least decent control of your throttle finger!
Basically, the only reason to run 2S is if your electronics can't handle more, in my opinion.
Shorty LiPos were typically used in race vehicles bound by rules to 2S, and used so that they could be moved around for weight distribution and also because of the ease of packaging all the electronics around them.
The Vaterra Ascender stock battery tray is configured to use them, somewhat of an odd choice - but it's a nifty battery tray in that it's low, centralized, and partly unsprung weight.
But, again, it's been traditionally hard to find 3S shorty packs.
The same for high mAh shorty packs, because when racing all that excess mAh is not used, just swap in a freshly charged pack for the next heat.
So, your high mAh LiPo is somewhat of a find, but - again, crawlers are not typically going to burn through a lot of capacity very quickly.
Very high capacity LiPo packs are typically used in go-fast bashers, because they are run at high speeds and are relatively inefficient.
Witness all the high-capacity packs that come with Traxxas connectors on them. Who wants to constantly swap batteries while bashing?
There's a company that makes a 12000mah 2S pack for standard Traxxas battery trays (gotta use an expansion kit, like you would for a 7-cell MiMh).
It's as expensive (or more!) as the Traxxas you'd install it in.
Whatever....
Hell, that same company makes a 6000mAh "Shorty" (in name only) pack that is 68mm x 45mm x 51mm, specifically to install in the Ascender.
That's practically a cube, and does WONDERS for a crawler's center of gravity... (sarcasm definitely intended, what a bunch of twats)
