hotwheels000
I have been plugging away at the things I wanted to change on the car.Rear suspension was next on the list.
Replaced the stock mono leaf with a 5 leaf pack. I then had a buddy make some new shackles for it. (no pics)
Then it was time for the shock relocation. My goal was to get ride of the old school air shocks. The ride was harsh and installation was less than steller, meaning the bolted directly to the trunk pan.
We started with the upper mounts. Several ideas were tossed around and then a decision was made. A 1.25 hole was cut in the rear sub frame. We fabbed up a piece of tubeing with one end capped and a hole drilled threw it for a Rancho shock stud. That assembly was welded into the subframe.
Then it was time for the lower shock mounts. Again many ideas were considered until we decided on this version. It is a piece of 5" square stock cut to fit the desired shape then welded to the slapper bars.
A pair of KYB gas adjust shocks were installed. Talk about a difference in ride quality. Couldn't be happier... Thanks to Kenny for all his help fabbing, welding and putting up with me...
