In 2015 I entered the RC4WD ECSC and didn't have a scale truck. On top of that, this was to be the first event I ever participated in. I had always wanted to build a scaler and entering the event was the push to get a project going.
I acquired an SCX frame from a friend and picked a New Bright Chevy body and some axles off of the RCC For-sale section.
Looking through some other threads at the time that used this body, I saw an awesome Pre-runner build and loved the front bumper he built for it. I though I would try something similar. (I was going to link to it but Photo Bucket has completely destroyed that thread :x)
I built my own light and servo winch controller, added and interior and cage, some paint and set out for the event......
Over the next 3 years and other events in our area I found and corrected a lot of weak points. Better winch, Some cage failures and other minor things. I have been slowly upgrading it as time went on, changing over to TKO axles and some motor upgrades.
The truck is starting to show some age....
Fast forward to today.......
Once again I'm registered for the '18 ECSC and with new axles on the market, thanks to the SCX10II release, it's time for a complete rebuild.
I high centered on the tree obstacle last year and had to winch the entire length because of the large pumpkin for the SCX TKO diamond axles and small diameter tires. This killed my time for that course. I had planned to switch over to an SCX10II style but lack of parts and aftermarket options left me having to run the old style. I was waiting for a diamond option and SSD delivered.
Since getting a 3D printer for Christmas and purchasing a CNC mill a few years ago I decided to make and incorporate as many of my own parts as possible. I started with a model of where I'm headed.....
To relocate the motor forward and 3D print an LS I either had to buy a scale transmission or modify the stock transmission. I didn't feel given the sweeping exaggerated SCX chassis, that a scale tranny would work or look right so I relocated the stock transmission with new mounts and brackets.
All of this is now printed in ABS but I started prototyping in red PLA.
I swapped the input shaft to the other side of the transmission, mirriored the motor plate in CAD and cut a new mounting plate. Setting mesh is tedious but not impossible. Trial and error until it's just right.
The new location will push my center of gravity higher. I may change over to a plastic slipper to reduce this. I'm planning putting the batteries under the drivers seats to counteract this. Thats all TBD for now.
Next step was to make my own tCase. I purchased the SSD hardened gearset for the SCXII and modeled around these. The layout is to minimize the angles for all of the input and output shafts. I also wanted to reuse my MIPs. I found an RC4WD punisher shaft in a 65mm length and was able to make it all work.
Tying it all together...
I have a few other additions I'll post a bit later as I move forward. I touched on the shock buckets so I have room for headers and started modding the hood on my body.
