But is there a drag brake?
EDIT: Ohhh, not sure but others in SCX area were saying it's same esc. Drag brake on it appears to be set with a small jumper on physical contact pins like the latest Axial esc.
Another link direct to Hobbywing:
http://www.hobbywing.com/product_show.asp?id=300
Axial AE-5 for comparison, info from Axial's site about AE-5 ESC:
The AE-5 ESC features include 3S LiPo capability, adjustable drag brake and it's waterproof! Settings can be easily switched “in the field” between LiPo and NiMH battery types with a simple jumper – no more complex procedures!
• Jumper 1 provides a simple plug and play choice between LiPo or NiMH batteries
• Jumper 2 switches drag brake settings
• Waterproof design with waterproof on/off switch
http://www.axialracing.com/products/ax31144
Axial AE-5 ESC with drag brake at RPPHobby, I've ordered from them many times and great service, fast shipping, and good prices!
http://www.rpphobby.com/product_p/ax31144.htm
Vaterra ESC on HorizonHobby site (back ordered) sure looks exactly like Hobbywing Quicrun except for the two little screw mounting ears on the case and cross cut milled into red heatsink. As best as I can read via web the jumper settings are labelled the same, but I don't know 100% sure
http://www.horizonhobby.com/wp-60a-fwd-rev-brushed-esc-dyns2210
WP 60A FWD/REV Brushed ESC, DYNS2210
Waterproof for all weather operation *
LiPo and NiMH compatible
Program functions changed with the use of jumper pins
Up to an 8T motor limit
Removable mounting tabs create an even smaller footprint and allow hard mounting in a wide variety of vehicles
Crawler running mode
Pre-wired with EC3 battery connector and RTR compatible motor bullets for easy installation
http://www.vaterrarc.com/Products/Default.aspx?ProdID=VTR03014
Link to original ESC discussion:
http://www.rccrawler.com/forum/axial-scx-10/535961-my-motor-esc-choice.html
