Another question came up on setting up wheelbase - my new build is a WB3 and I'm just building the rear axle and see that I have two complete driveshafts for the rear - which one do I use? I can't find anything anywhere on which one.
The instructions on the gearbox said to 'use the shorter one' of the two for the rear, but then there is another complete driveshaft in the parts bag for the rear axle which makes it really confusing.
And the slip-fit of the shafts are clocked - they only go on one way! Nothing in the instructions about that either.
EDIT: I think I figured it out - the back half is the same as my K10 so the same driveshaft which is the longer one. I think they gave me an extra front driveshaft - that's what it matches.
The 302mm WB3 has the 12mm spacers in the front links as well as the back - so I gain about a half inch over the K10. It should crawl better too.
