axial rock lizards ?
jaycruz
federal way
I still run the stock axial rock lizards ,and wondering if anyone uses these in comps ,they seem to work well for my crawling ,will the moad m2 compound tires make a difference?
I thought that I did well with the stock Lizards. I picked up the Pro-Line Flat Irons, and I doubt that I'll ever mount the Lizards again. It's that huge of a difference! The M2 or M3 Moabs are also great tires. "thumbsup"
i'm going to keep mine till they start showing some wear.... Master my skills then move on to a different tire that will make it 10000% easier :D
Not a bad idea. Work on the suspension setup. The greatest tire in the world aren't worth squat if the suspension doesn't work right.
I would however suggest cutting the tires. I used a pair of dykes & cut the straight bars out of the center tread, leaving the V tread facing each direction. It made a big difference.
