axial scx10 stock esc qeustion ?
hartford
Hi guys i have the stock scx10 esc . i have been running it since i got the truck but all of a sudden its tweaking out. It drives forward just fine but when i go to reverse it doesnt do a thing in less i am full throttle. why is this? should i just get a new esc? i still have the stock radio and transmitter is it possible that its just the radio?? if any one could help i would be appreciative???
i was think about the tekin fxr with the 35 turn if i have to replace stock esc again please help
If you have the AE-1 ESC then follow these instructions:
http://docs.axialracing.com/instructions/ax24250-i001-ae1-esc.pdf
if you have the AE-2 esc follow these instructions for calibration:
http://docs.axialracing.com/instructions/ax24259-i001-ae2-esc.pdf
You didn't get the ESC wet did you? If calibration fails to correct your problem then give axial a call, they have great customer service.
thank you for your help i did try that and that still doesnt work i can get it to work for 30 seconds or so after turning on the esc then it quits. I will try to contact axial to see what they have to say. if any one else has any suggestions please feal free to post !
i did that and it will work for 30 seconds and then it will stop i can drive forward but i cannot go in reverse should i just replace the esc. is that what it is forsure thats what iam wondering cuase if it is ill just pick up a tekin combo
