  • RCSC
Mini LMT Build Completed
HVACTeacher
Canda
When the Mini LMT came out I wanted one bad, when Megalodon released, I was done.
I wanted to do a build like my large LMT; over powered the way a monster truck should be!
I picked up a whole bunch of different motors to try along with a Spectrum 2-1 that I had from another mini. I wasn't happy with it. I ended up shoehorning in a Velineon 380 motor that I paired with a Furitek ESC I had.
Unfortunately I couldn't get the motor to turn using that ESC. I tried every setting possible. Only thing the worked for two seconds was changing the BEC voltage, it responded positively for a few rips on the TX, then it stopped. It just seemed like the drive train was binding up, which I knew it wasn't.
Like an idiot I tried a few different ESC's that were unfortunately not compatible with sensorless motors. Had I looked at the complete instructions instead of just ripping the package open and soldering I would have saved a few evenings (I was trying to keep the packaging small).
In frustration I went to my LHS. We talked about it for a bit. I determined that it had to be the ESC for whatever reason. The specs matched up the the motor, but I suspected it didn't have the jam. I elected for a tried-and-true unit I have used in the past; a NIP CC MMP they had on the shelf.
I soldered that baby up tonight... AANNDDD immediately ran into Castle Link connection issues on my laptop.
I honestly spent two to three hours messing with it. Out of nowhere I finally got it to connect for a second time, I then hastily made the changes and saved it.
Not sure why my computer suddenly decided it didn't want to recognize that USB CC Link. I wasn't touching it at the time it stopped working. Just reviewing the settings when ZAP, it just quit.
Anyway, glad it's done and I'm looking forward to getting it out for a rip in the coming days!
Mini LMT
- Spektrum SX108 servo
- CC MMP (BEC @ 6.0v)
- Velineon 380 Motor
- Spektrum SR310 (DX2e)
I got the body mounted up today.
I had to move the RX forward 1/2" to clear the roll cage. I also had to remove the body mount on the motor side along with the lexan driver figure over the ESC. It looks so sick though!
I didn't have a fully charged pack, but something from storage, with the transmitter set to 75% it will instantly pull wheelies on grass. AND the motor was ice cold :cool:
Here it is, done! For now.. I'm sure I'll have to put a servo in it at some point.
Thanks!
No, unfortunately I haven't taken the time to figure that out.
It was NIP at the time. Whole thing was strange. Almost like it couldn't sense the rotor rotation.
I have another Furitek running a HW sensorless motor just fine.
I will eventually hook-up some stuff on the beach to test and report back.
Edit;
Took it out for a rip tonight :)
HH has a sale on so I decided to pull the trigger in a few things. This servo was half off so I thought, why not. I also wanted to add LEDs to the shell and this kit lists as the one.
The servo is super fast, really impressed with that upgrade. It's also metal case and adds just a bit more weight up front.
Next was the lights. Due to the lenses and mounts not fitting I had to glue them in.
I was planning on using the red lenses, too bad they don't fit.
I also only had orange translucent paint or I would have hit them up with some red.
Maybe something for down the road?
Either way it adds some flare, hopefully Stan approves.
