The XR10 Setup Sheets are now available: Click here for the blank Setup Sheet!
Click here for my setup from Nationals 2010.
Brandon, you guys have any team set up's yet? I've seen the builds but knowing the little stuff will be great as well.
Great idea Axial. Obviously Scott moving in there has paid off.
It's better to run the rubber and just barely tighten the nut.
Just added it to the post above "thumbsup" Cant wait to see these sheets being used by everyone.
BENDER and Scott are working on there setup sheets as well.
Here's a great tip for the battery mount. Can be done with what you have already. Then you can easily get an 1800, 1500, or 1300 in and have your CG as low as possible.
Removed battery tray and dremeled it, flipped it, and mounted it upside down on radio tray. Then bent the mounting tab downwards.
Junior
Look closely at the pic. The plastic ball is on the right, and the rubber is on the left with a washer on each side.
If you are forcing the shocks anymore than in picture, then you are putting unnecessary side loads on your shock shafts and seals.
I would recommend that if you have a tip,
then post a pic
The point of my pic was to show everyone the freedom of movement between the two choices, rubber or plastic. Has nothing to do with either of our setups.
No flex issues here:
I found mine to have considerable slop where the lower links connect at the skid. The links slid back and forth on the mounting screw. To rectify this I used a 1mm washer to the outside of each rod end.
