Highmark
Uhhh yeah, that would just be stupid.
You mount the batterys on the knuckles because it's the lowest possible spot you can mount them without looseing ground clearance in another area.
Mounting them on the wheel would make them lower, but only when the wheel is at a certain point in relation to the ground. At other times the batterys would actualy be higher than if they where mounted on the knuckle, not to mention the possibility of damage from flailing them around on rocks.
Also, as previously stated by mrpink you add rotational mass which is bad. Rotational mass makes the rig react slower to throtal inputs, and react quicker in rollover and downhill situations. All adding led wieght to the front does is move the COG frontwards. It's okay on 2.2 because the wheels are smaller than on a super, but if you add a proportionaly large amount of mass in the same location on a super you'll reach a point of deminishing return VERY quickly.
