Been look and can't find.
Double J
between heaven and hell.
Maybe you can.
I've been looking for something that is like a set collar but has a 6-32 stud on it.
Not sure what it'd be called and I've used many different terms on google with no luck. The closest I've found is a pushrod connector but it's a little on the small side.
It'd look something like this. Kinda like a heim joint but wouldn't have the bearing in it.
Hope that explains it.
Thanks for any help.
search for "collar" on this site..... Should come up with something.
"set screw shaft collar" looks really close to what you want but without that 6-32 stud.....
www.mcmaster.com
yeah I had no problem finding set screw shaft collars but I haven't been able to find something like pictured or that would work in a similar fashion.
Thanks though.
You check Spring Air or Robart websites at all? I know what you are talking about, but not sure on where I saw it either, but those two sound right. I think Robart might make something like that for landing gear door mounts I think, otherwise check other RC Plane retract sites once too.....
Hope it helps.......
