Beginner Airbrush
ede670
Highlands Scotland
Hi all,
I am still deciding wether to try an airbrush or just use the good old spray can,
Would a simple brush and propellant can be a good start or would I be just as well off using cans I am planning a 2 tone paint scheme any input would be greatfully recieved "thumbsup"
If you are going to want to get better at painting and try a few things then get a gun.
If you are just going to paint the one body, then get the can. Cause the brush will just sit on the shelf.
I recently started painting all my bodies with an airbrush, actually it was about a year or so ago.
I like using an airbrush cuz it is cheaper in the long run and you can mix custom colors. Plus even my cheap airbrush is better for doing fades than a spray can.
I tried the can of propellant and hated it, too limited. I bought my airbrush at Hobbytown, it is a Badger Model250, single action, external mix, bottom feed.
http://www.badgerairbrush.com/airbrush2.html
I paid like $50 for it and it works great. I also picked up an adapter at the hobby shop to connect the airbrush line to the quick release coupler on my home air compressor, that is the best way to go I think.
Thanks Guys,
I am wanting to experiment in the future so I might just invest in a airbrush and a cheap compressor I think if I start of basic and then see what comes out ..;-) a basic airbrush spray pattern does it go down to 1-2mm for fine details stuff...
look for a single action to start out with. badger and paasche make some great stuff. I think Iwata might even have a single action as well. once you get good with that then go to a double action. great for details, shadowing and highlights.
I picked one up a year or so also, I have a Badger Anthem 155. its a dual cation internal mix. it comes with a hose that will attach to a can or compressor, several bottles and tools. it was $125 new. but it gives me great control, and will still lay out a good base coat quick like a spray can does.
I've got a Badger Model 175, "Crescendo®" .. I took a few classes a couple of years ago. Never really got that good. Good enough to do a little custom work.
I have the same airbrush. Love it.
Thanks
The Badger range seems to be one of the most used over here in the uk and seems pretty cheap for spares as well .....next thing to find is a cheap compressor I did read somewhere you can use an inner tube with an adaptor so I might get a truck inner tube I think a tractor will be 2 large ;-)
